quebra cabeças e similares...
Mensagempor decarvalho » domingo jan 21, 2007 6:54 pm
carissimos
para aliviar o stress dos dias em que não se rola de AC, aqui vai um intermezzo...
Se conseguir ler as primeiras palavras o cérebro decifrará automaticamente as outras...
3M D14 D3 V3R40, 3574V4 N4 PR414, 0853RV4ND0 DU45 CR14NC45 8R1NC4ND0 N4 4R314. 3L45 7R484LH4V4M MU170 C0N57RU1ND0 UM C4573L0 D3 4R314, C0M 70RR35, P4554R3L45 3 P4554G3NS 1N73RN45. QU4ND0 3575V4M QU453 4C484ND0, V310 UM4 0ND4 3 D357RU1U 7UD0, R3DU21ND0 0 C4573L0 4 UM M0N73 D3 4R314 3 35PUM4.
4CH31 QU3, D3P015 D3 74N70 35F0RC0 3 CU1D4D0, 45 CR14NC45 C41R14M N0 CH0R0, C0RR3R4M P3L4 PR414, FUG1ND0 D4 4GU4, R1ND0 D3 M405 D4D45 3 C0M3C4R4M 4 C0N57RU1R 0U7R0 C4573L0. C0MPR33ND1 QU3 H4V14 4PR3ND1D0 UM4 GR4ND3 L1C40; G4574M05 MU170 73MP0 D4 N0554 V1D4 C0N57RU1ND0 4LGUM4 C0154 3 M415 C3D0 0U M415 74RD3, UM4 0ND4 P0D3R4 V1R 3 D357RU1R 7UD0 0 QU3 L3V4M05 74N70 73MP0 P4R4 C0N57RU1R. M45 QU4ND0 1550 4C0N73C3R 50M3N73 4QU3L3 QU3 73M 45 M405 D3 4LGU3M P4R4 53GUR4R, 53R4 C4P42 D3 50RR1R! S0 0 QU3 P3RM4N3C3 3 4 4M124D3, 0 4M0R 3 C4R1NH0.
0 R3570 3 F3170 D3 4R314
passatempo
Mensagempor mribeiro » domingo jan 21, 2007 10:08 pm
Em dia de verao estava na praia observando duas crianças brincando na areia.
Já deu para entender que é facil de decifrar.
mribeiro
mribeiro
Mensagempor albi » segunda jan 22, 2007 11:24 pm
Só custa a começar a embalar, depois já naõ se pode travar a leitura.
Boa ideia.
Artur
albi
Para quem quer embalar em inglês....
Mensagempor decarvalho » quarta jan 31, 2007 3:56 pm
Carissimos, aqui vai outro passatempo quebra cabeças...
The European Commission on Languages has just announced an agreement whereby English will be the official language of the European Union rather than German, which was the other possibility.
As part of the negotiations, the British Government conceded that English spelling had some room for improvement and has accepted a 5- year phase-in plan that would become known as "Euro-English".
In the first year, "s" will replace the soft "c". Sertainly, this will make the sivil servants jump with joy.
The hard "c" will be dropped in favour of "k". This should klear up konfusion, and keyboards kan have one less letter.
There will be growing publik enthusiasm in the sekond year when the troublesome "ph" will be replaced with "f". This will make words like fotograf 20% shorter.
In the 3rd year, publik akseptanse of the new spelling kan be expekted to reach the stage where more komplikated changes are possible.
Governments will enkourage the removal of double letters which have always ben a deterent to akurate speling.
Also, al wil agre that the horibl mes of the silent "e" in ! the lang uag is disgrasful and it should go away.
By the 4th yer people wil be reseptiv to steps such as replasing "th" with "z" and "w"with "v".
During ze fifz yer, ze unesesary "o" kan be dropd from vords kontaining "ou" and after ziz fifz yer, ve vil hav a reil sensi bl riten styl.
Zer vil be no mor trubl or difikultis and evrivun vil find it ezi tu understand ech oza. Ze drem of a united urop vil finali kum tru.
Und efter ze fifz yer, ve vil al be speking German like zey vunted in ze forst plas.
If zis mad you smil, pleas pas on to oza pepl.
Mensagempor Luis Almeida » quarta jan 31, 2007 5:51 pm
Esta, nem com nem sem embalagem!!
No quinto ano, estaríamos todos a falar inglinês. :lol:
Muito bem observada, companheiro DeCarvalho!
Saudações a todos. :wink:
Luis Almeida
Charneca de Caparica
[ Rimor Europeo 87P ]
Luis Almeida
Mensagempor Carlos Lopez » quarta jan 31, 2007 5:52 pm
Boa Noite
Será assim tão fácil aprender alemão?
Carlos Lopez
Carlos Lopez
relatorio do arbitro Xistra sobre o caso Miccoli
Mensagempor decarvalho » quinta fev 01, 2007 11:26 am
Carissimos e amigos lusofonos....
O jogador da equipa visitada, Micolli, desmandou-se em velocidade tentando desobstruir-se no intuito de desfeitear o guarda-redes visitante. Um adversário à ilharga procurou desisolá-lo, desacelerando-o com auxílio à utilização indevida dos membros superiores, o que conseguiu. O jogador Micolli procurou destravar-se com recurso a movimentos tendentes à prosecução de uma situação de desaperto mas o adversário não o desagarrava. Quando finalmente atingiu o desimpedimento desenlargando-se, destemperou-se e tentou tirar desforço, amandando-lhe o membro superior direito à zona do externo, felizmente desacertando-lhe. Derivado a esta atitude, demonstrei-lhe a cartolina correspectiva."*
teste de senilidade...
Mensagempor decarvalho » terça fev 13, 2007 9:25 pm
Teste de Senilidade
Abaixo estão quatro (4 ) perguntas e uma pergunta bónus. Tens de responder instantaneamente. Não podes demorar, responde imediatamente. OK?
Vamos lá verificar a tua inteligência ....
Pronto? Partida!!!
Primeira pergunta:
E stás a participar numa corrida. Ultrapassas a segunda pessoa. Em que posição ficas?
Resposta: Se respondeste que és o primeiro, estás
absolutamente errado! Se ultrapassas a segunda pessoa, tomas o seu lugar, por isso és o segundo!
Atenção à segunda pergunta!
Segunda pergunta:
S e ultrapassares a última pessoa, em que lugar ficas...?
Resposta: Se respondeste que és o penúltimo, estás errado outra vez. Diz lá, como é que podes ultrapassar a ÚLTIMA Pessoa?
Não és lá muito bom nisto, pois não?
Terceira pergunta:
A ritmeticamente falando! Nota: Cálculo mental apenas.
NÃO usar papel e lápis nem calculadora.
Toma 1000 e soma-lhe 40 . Agora soma mais 1000 . Agora soma 30 .
Soma mais 1000 . Agora soma 20 . Agora soma mais 1000
Agora soma 10 . Qual é o total?
Chegaste a 5000 ?
A resposta correcta é 4100.
Se não acreditas, verifica com uma calculadora!
Hoje não estás nos teus dias, pois não?
Talvez acertes na última pergunta....
...Talvez.
Quarta pergunta:
O pai da Maria tem cinco filhas: 1. Nana, 2. Nené, 3. Nini, 4. Nonó. Qual é o nome da quinta filha?
Respondeste Nunu?
NÃO! Claro que não é.
O nome dela é Maria . Lê a pergunta outra vez!
Ok, agora a pergunta bónus:
U m mudo vai a uma loja e quer comprar um escova dos dentes. Imitando a acção de lavar os dentes, consegue fazer-se entender e consegue fazer a compra.
A seguir, um cego entra numa loja e quer comprar um par de óculos de sol. Como é que ELE indica o que quer?
Só tem que abrir a boca e pedir...
É mesmo básico....!
Mensagempor Pluma Vermelhinho » terça fev 13, 2007 10:10 pm
Fantástico. Errei as duas ultimas. Excelente passatempo :lol:
Boas viagens e fiquem bem.
Pluma Vermelhinho
PING PONG..............................
Mensagempor decarvalho » terça Oct 23, 2007 7:20 pm
Mensagempor António » domingo nov 18, 2007 8:15 pm
Pois vamos lá ver se á solução par estes desesperados?
4 sujeitos encontram-se na margem esquerda de um rio junto a uma ponte de corda pendurada sobre uma profunda ravina. Estão sendo perseguidos por uma tribo de canibais famintos e só lhes resta 17 minutos de avanço antes de serem apanhados. Claro que para atravessarem apresentam-se-lhes algumas restrições: Só podem passar um máximo de duas pessoas de cada vez porque a ponte não aguenta com mais. E como está escuro, têm que trazer uma lanterna com eles cada vez que a cruzam, contudo há só uma lanterna (assim, em cada travessia alguém volta com a lanterna). A propósito, a ravina é muito larga para lançar a lanterna pelos ares. Eles atravessam a velocidades diferentes assim levam também tempos diferentes para cruzar a ponte: o homem A leva 1 minuto, o B leva 2 minutos, o C leva 5 minutos, e o D leva 10 minutos. Quando dois deles caminham juntos conta o tempo da pessoa mais lenta (assim, quando A e D cruzam a ponte levam 10 minutos).( e conta depois o tempo de volta do que regressar com a lanterna) ( tipo A+D= 10 minutos volta A + 1 minuto)
Como conseguem todos estar na outra margem em 17m ??
Um Abraço
António
António
quebra cabeças do maestro e Boas Festas....
Mensagempor decarvalho » domingo dez 02, 2007 4:58 am
Alo
companheiros de bom humor...
aqui vai o quebra cabeças do Maestro. Aqui fica deste modo o meu cartaod e Baos Festas 2007/08
Como se pode gerir da melhor maneira essa orquesta?
basta clicar em:
http://www.orapois.com/br/arquivos/0616 ... 19937g.swf
inteligencia artificial
Mensagempor decarvalho » segunda dez 10, 2007 5:36 am
VIVAM.....
aqui esta um link a nao perder..é de dialogo com a inteligencia artificial...
que "adivinha" o que se pensa..., e no que se pensa....
nao perca tempo em pensar em autocaravana (essa palavra nao existe no dicionario) mas pense por exemplo em caravana...e va respondendo aos questionario...em francès, inglês ou espanhol....
ora experimentem:
http://www.20q.net:80/
Mensagempor seco » segunda dez 10, 2007 10:21 am
Olá
Como estamos numa de música.....
http://svt.se/hogafflahage/hogafflaHage ... tekor.html
seco
seco
Mensagempor seco » quarta dez 12, 2007 5:52 pm
Agora a música é outra!
Vamos a uma de imaginem:
Imagina que estás a pilotar um carro e mantens uma velocidade constante.
Do teu lado esquerdo encontra-se um cisne enorme.
Do lado direito um grande carro de bombeiros, que mantêm uma
velocidade idêntica à tua.
À tua frente galopa um cavalo, que é bem mais alto do que o teu carro,
e não consegues ultrapassa-lo.
Atrás de ti vem um helicóptero rente ao chão.
Tanto o cavalo como o helicóptero mantêm uma velocidade idêntica à tua.
O que fazes para sair desta situação em segurança?
Pensa um pouco......
A resposta está mais abaixo....
Resposta:
- Sai do carrossel e deixa de beber, que o álcool está a dar cabo de ti...!
seco
seco
